Author Topic: HI GUYS fender fit  (Read 186 times)
Offline BLASTERBOY
  • Newbie
HI GUYS fender fit
« on: January 29, 2018, 04:13:06 PM »
Need to know if a XJ Cherokee drivers front fender will Interchange have a 1997..will 1996 fender work..
Re: HI GUYS fender fit
« Reply #1 on: January 29, 2018, 06:51:44 PM »
rockauto calls for different part numbers for 96 and 97
« Reply #2 on: January 29, 2018, 06:59:30 PM »
They are different in that the 97+ are more rounded, and the 96 have sharper corners. If you are just going to replace 1 fender, it won't match up.
Offline BLASTERBOY
  • Newbie
« Reply #3 on: January 29, 2018, 11:23:32 PM »
I KNOW THEY CARRY A DIFFERENT PART NUMBER..WILL IT WORK...IF I'M CUTTING FENDER FOR POCKET FLARES...KNOW WHERE I CAN GET A 96 FREE..JUST CHECKING..IF NOT ..I'LL BUY 97..THANKS FRIEND
« Reply #4 on: January 30, 2018, 06:57:15 AM »
Caps lock
« Reply #5 on: January 30, 2018, 08:50:28 AM »
The body style changed between 96 and 97. If you need a fender for your 96, you should look at all the 80's-early 90's Cherokee's, up to 96. 97-01 were a slightly different body style.
Offline XJRV-Maki
  • salt no carry
« Reply #6 on: January 30, 2018, 09:38:43 AM »
however....the different body style fenders do bolt up perfectly fine with the other if it's just a trail rig....mismatched body panels are like wrinkles around your eyes, the more fun you have the more you get.
