Author Topic: Uneven wear on winter tires  (Read 174 times)
Offline MattG
  • Probie of the year!
« on: February 02, 2018, 01:48:42 PM »
I noticed some uneven wear on the inside of my passenger rear tire, I just had the tires balanced and aligned. I replaced the springs and shocks in the rear at the end of 2015, I guess they could be shot...
What do you think? Replace the shocks?
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
Re: Uneven wear on winter tires
« Reply #1 on: February 02, 2018, 02:13:22 PM »
 Why'd you replace the springs?  You put lowering springs in?
Profile for Team_Oscar
Quote from: Theo Maassen
Offline MattG
« Reply #2 on: February 02, 2018, 02:21:36 PM »
no, one of the springs broke, so I replaced with new moog springs and monroe shocks
  • Honorary Members
« Reply #3 on: February 02, 2018, 03:15:45 PM »
 Either
  A) the Alignment is still off or is off again... or
  B) The springs have sagged significantly since the alignment was done... or
  C) The tires were already worn... or
  D) You drive like an asshole and should stop... :rotflmao:
 Shocks only absorb impact and settle the springs... If the vehicle isn't bouncing for the next 1/4 mile after a bump the shocks are good.
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #4 on: February 02, 2018, 03:35:00 PM »
Move the dead body to the other side of the trunk.
« Reply #5 on: February 02, 2018, 03:53:37 PM »
lose some weight
« Reply #6 on: February 02, 2018, 08:20:49 PM »
I’m with Draz
« Reply #7 on: February 03, 2018, 06:28:49 AM »
Hard to tell in picture but that's usually a sign of bad camber
« Reply #8 on: February 03, 2018, 06:30:18 AM »
Or phat camber in some circles hahaha
« Reply #9 on: February 03, 2018, 07:31:57 AM »
Thats so bad . Who would do that and think it helps with handling or looks cool.  Yet they will pull over a lifted Jeep for not enough tire coverage or a truck with to much smoke .   FjR68
« Reply #10 on: February 03, 2018, 07:50:17 AM »
They are pulling these guys over too now. I think it started in two places. In the low crowd a little extra neg camber helps tuck offset wheels. Also I'm pretty sure some extra camber helps handling on drift cars. Like everything the all show bros always take it too far!
