2000 TJ serp belt tensioner
The 00 uses the spring loaded self tensioner right?  I know my 03 does, but my 95 uses the PITA screw adjust.
If it does, just turn, R&R and let go.
If you 2000 is like my 2004 motor, the spring loaded tensioner is right below the alternator pulley. Just attach a breaker bar to the square hole in the center, and move the tensioner as needed to remove and replace the belt.
