2017 ford escape under the knife
TJlongworth
Moderator
As many people know Trish's Ford escape has been a bit of a headache from the very beginning. For those that don't know here's a bit of a recap.
She purchased the car from carfax shortly after we started going out. She had the car for about a week before the check engine light came on, which I quickly diagnosed as the car needing a head gasket. Back to carmax it went for them to take it to the ford for a whole short block because of an active TSB for a bad block design. It sat on the ford lot for a year before they had all the parts to do the job. Carmax was great about rental cars, and we drove the wheels off the 3 we had.
She got the car back and all seemed good until I checked the oil 2 weeks after picking it up and there was none on the dipstick. It took a quart to get it where it needed to be. turns out they pinched a turbo drain line putting everything back together and the oil was leaking everywhere. I took the opportunity to tear the service dept. a new one. Upon further inspection all the zip tie tabs were cut, a few bolts were not tight and hoses were routed it the wrong spot.. After ripping the service guy and a manager a new one they told me the next available appointment for them to fix the oil drain line was 3 weeks and they don't supply rentals.. FAWK THEM. I asked for the parts at no cost and i'll do it myself.
Since then the car has been great until Thursday the 7th. At this point she has put 20 k on the car. Trish calls me in work and says its making a knocking noise and you could hear it on the phone. I drove her to work and stopped at gengras ford. The service writer was great to work with. He explained that there was little to no warranty on the engine work hoffman ford did, but if it was indeed an engine related issues they would work with me if I had them do they diag. sure for 170 ill give it a shot, went home and before putting it on the trailer tossed it on the lift and quickly realized it was between the back of the motor and tranny. Wonderful
Towed the car to ford even though it most likely wont be covered, got to talking with the shop Forman, he told me the flex plates crack all the time, and when they do it sounds like a knock. flex plate, cool, how bad could it be. Still going to pay them to diagnose. Unfortunately they tell me what I already learned and I'm out the 170, To diagnose any further they need to pull the tranny, and by that time they might as well do the job... 3400 in labor!
I thanked him and said since the daig didn't buy me anything, can you write up a quote for everything I need to do the job myself, To my surprise he did, even down to the oil ! 1300 out the door including core charges I have gained another project.
Parts included,
-All the 1 time use hardware
-Torque converter
-front pump for the tranny
-filter for tranny
-New flex plate
-fluid
-some seals and o-rings
To say it was labor intensive was an understatement, the amount of stuff that had to be removed was insane. The book said 12.8 hours to pull and replace the tranny. It ended up taking me almost 18 hours to do the entire job. I give the dealer techs a lot of credit to do this work day after day.
After further inspection I'm confident to say that the flex plate doesn't just fail out of nowhere, Duh, but everyone seems to believe that the flex plate fails which causes the torque converter to wobble, which takes out the pump. However I think the failure happens in reverse. the front pump bushing gets worn out from a lack of lubrication causing the torque converter to wobble, which causes the flimsy flex plate to crack over time. This is just a guess but it seems to make more sense.
All in the job cost about 900 bucks and a few hours, I was also able to fix a bunch of the crap the last dealer half A$$ed
Pics of the job
Sent from my ThinkPhone by motorola using Tapatalk
I had to get creative making a custom flywheel holding tool. If the job wasn't complicated enough, when torqueing the bolts for the flywheel or removing the torque converter nuts, the engine can only rotate clockwise. If the engine is rotated counterclockwise the timing belt tensioners release tension....
I a fan of ford products, however this one is not built like the old ones. It is not only a disposable vehicle but also very fragile
It's a shame to buy a car from a high-end dealer (Carfax doesn't sell junk as a rule) and have these issues.
Jess had a Mariner (Fancy Escape) and my Mom had a Taurus that we gave to Cait after she passed. I hated working on both of them for various reasons. I feel as if they took direction from Jag seeing Euro type engineering.
I had a few Rangers and F150's back in the day that I enjoyed but no longer a FORD fan. Then again, they all have issues. Pick your poison I guess.
Good job. I had same thing happen with dads Cummins (Alan’s old one) dad called and said he thought truck was done, making knocking and shaking and almost couldn’t make it home. I didn’t know if rod knock or leaking injector or loose flywheel bolts.
Nope flex plate broke, was completely separated all the way around the outer diameter of the crank bolts. Was driving that way. New sfi flex plate and good to go.
You had your work cut out for you but the techs do this work all the time so they know what to do and where and what bolt sizes and even some short cuts they figured out along the way for disassembly and reassembly.
It seems to me that after doing a major project like this you always feel better for doing it yourself.
Congratulations.
Although, transmission work should be done laying on your back on the floor looking up or it's cheating.
Nice work Tom, sucks to have to have done all of that, but at least you know it’s good for a good amount of time!
Also, with about an hour where mosquitos are mercilessly attacking you as the sun goes down.
Is there such a thing a good, reputable mechanic anymore?  Was there ever?  At best, they are very few and far between.
If you weren't as skilled as you are, you would have been just another screwed customer bending over saying "Thank you sir, may I have another".
That's just living in a third world country right there!
We're on our 3rd Escape.
I can say that I would have NEVER tore into one to that deep.
LOL
        I Commend you.
