wrongcaptcha
I have both listed on CL, but I figured someone here may be able to use these:
I've got a Good Running 2.5L from a 93 Wrangler, with AX-5 Manual Trans, and NP231 Transfer Case. Motor will be missing a few of the accessories, but is otherwise complete. Previous owner had it put in and told me it had about 60k miles on it, and judging from a quick look under the valve cover, she could be right (or at least it has a new head -- was pretty clean). Transmission shifts well, no grinding or poping out of gears. 4 high and low work as well.
Doing a motor swap on my jeep, no longer need.
I pulled it out last week, was driving it around (have a short clip from behind the wheel) with no troubles.
I would rather sell it all as one unit, its bolted together with a fairly new clutch right now (<5,000 miles). $500 takes it all, or $300 for the motor and $300 for the Trans/T-Case.
The tires:
https://newlondon.craigslist.org/pts/5473233835.html
The tires:
