J
jon
Alright I have the motor in and everything plugged in.
Fuel pump is wired, and every sensor connected except the vss.
I have attached the hot connection, start and key on correctly. It will turn over but the pump will not run, and I don’t get any spark. Pump does work when I attach it directly to hot. I have the pump wired to the relay in the underhood fuse box.
My guess is the auto shutdown relay? Help?
