R
radioman89
i have an 89 yj with a 2.5l 4cyl. A few months ago i replaced the starter on it, and not too long after that every once in a while i would drive it, shut it off, and then it would turn over but not start. The first few times is happened i waited a while and then it would start just fine. Well i went out to eat one night and guess what, it wouldnt start. So after a little while a guy who used to have a cherokee with the same problem told me it was most likely the started soleniod. So i stuck a screwdriver inbetween the posts and it fired right up. The next day i took the solenoid off and cleaned up the terminals to get rid of the corrosion. After i put it back together it worked fine. It sat for 2 months and then i started driving it agian on saturday. This after noon i went to go to the store and once agian, it turns over but doesnt start. I went to auto zone to get a new solenoid, which is a motorcraft starter solenoid, i came home put it in and it still wont start...so if anybody has had this problem, or knows what could be causing this problem, please let me know...i was thinking that maybe its the coil, but the haynes manual says that you cant test it without some tool, and auto zone doesnt carry it...
