Yea.....It would most likely be custom from Clayton, great stuff though....
So your in Mass., I was off.....
You building this for the street or the trail?
Not sure if your going to get desired spring rating if for the street, the
squat factor under accell might be hard to tune......
Whats your est. hp when complete?
44's are up to the job.....
Ever consider stretching the wheel base?
But really, street or trail?
Detour!!! Your a pretty smart guy!!!! Finally someone understands!!!! Tuning a 4 link for this application is very high tech stuff with a great knowlege required by the driver/mechanic to make a 4 link work optimally. At this point I don't have that kind of knowledge, and it takes a long time to be proficient to make the adjustments to the suspension. This is going to be a street/sand drag/ trail. Without N2O the engine dynos 742 Hp @ 5200 and with the juice 938 hp. Greg Hunt of Kiwi Engineering in Old Saybrook tuned it and told me if this engine was in a Javlin or AMX it would be a 8 sec car. The 44's aren't the optimal axle at this point but I havent broken anythig yet. The rear axle has Strange/Currie axles and a Eaton ELocker and the front is stock I run a BW 1339 QT which I think helps to share the load. Someday after the budget recoups a set of Dynatrac axles will be added. The wheelbase is streched to 98 inches now running Waggy springs. I've gotta get this back together to make the Monson Mass hill climb first race of the season. Plus I'd like to run against a guy buy the name of Fuzz 401 from the Bulltear board in the quarter mile( he runs a 401 in a CJ7). This rig is not for hard core rockclimbing as I have way too much money in it to bash it all to h*ll .I'd have to put a fuel cell in it to run Southwick but I may. So I'll give Clayton a call today to see if they really can help me. Jeff
