97 grand cherokee
ctaxle
what t/c came in these jeeps? auto ,6 cyl. jeep wont go into 4 lo , only to part time 4x4? i am thinking linkage problems. pete
does it have 2wd?
Is it limited or basic ZJ?
The limited usually is all wheel drive... which is 4 hi and 4 low only...   that is the NV242  (PITA  t-case)
There is allso the NV249 which has 2wd, Full Time 4wd, Part Time 4wd, and 4 low
Then there is the NV231 which we all no from the TJ, 2wd, 4wd and 4 low
Pete,
ZJ models '93 thru '98 came with the followoing transfer case models:
Keep in mind, this info is out of a "Haynes" manual.
NP231 - Part Time t/c w/ low range reduction gear
NP242 - Full & part time t/c w/4 operating ranges providing both 2wd and full time 4wd, has locking mechanism for undifferentiated 4wd in high & low ranges.
NP249 - All-the-time t/c w/ 2 operating ranges and a neutral position. The 2 ranges are 4 high & 4 low. Torque is distributed to front & rear axles thru a differential and viscous coupling in the t/c. Also equip'd w/ low range gear reduction for off road.
FrankTheDog is on the money.
Occationally I've seen t/c cases jump out of 4LO if you don't use it a lot. When I first bought my jeep I couldn't use the 4 wheel drive at all.  The previous owner never shifted it out of 2 wheel.  Once I started exercising it, it's worked fine ever since.
Try shifting into neutral at a full stop, then engage 4LO.  If it still doesn't go in you may have to recalibrate the linkage adjustment - it's easy to do.  Sometimes it's just a matter of lubing or tightening it. Call me if you need the procedure.  All you need is a 1/8" shim.
If that doesn't work you may have to check your shift fork for cracks, worn inserts or binding.  I've never had one apart so I can't offer help there.
The New Process metal tag is easy to get at on the t/c.  Is yours still attactched and can you read the model number off of the plate?
Good luck.
Ron
860-621-8413
jeep@ardvrk.com
