Advice Needed
  • Thread starter Thread starter HookSetSteve
H
HookSetSteve
I just got XM Radio for home work and a car kit
Does anybody else have it mounted in a TJ if so where did you mount the antenna
It needs to be on a metal surface but not obstructed
Thanks
I just got Sirius last weekend. I don't think you need it mounted to metal (except its a magnet mount!) The home kit has a flexible mount with screw holes - works good. I tried the car mount antenna in a window at the house (wood - not metal) and it picked up fine. So zip tie it to the roll bar or magnet mount it on your hood or fender (facing up). It'll work fine. BTW, you'll get hooked on SAT radio! :smt102
You can read a lot over at Rubicon Owners Forum, but the general thought I have read is you dont need to mount it outside on a open top Jeep. The signal will not be affected by the hard or soft tops. So most guys mount them to the top of the roll bar...
