Aluminum Tie Rods
  • Thread starter Thread starter HookSetSteve
H
HookSetSteve
I think some of you are running the aluminum tie rods
Who makes them and about how much are they and are they worth it
My stock one is a bit bent and time to upgrade
TIA
What's you opinion on these VS. the HD ones like  the Big Daddy Tie Rod?
Steve said:
You can probably find the knock-offs for bit cheaper, but Troys version is much stronger, and uses larger diameter stock.
Who makes the knock-offs and where can I get some info
I wanna explore all my options
personally I wanna know what material they make these out of.
aluminum will yeild a lot sooner than steel.  just wondering if its some special alloy
Tina has one of these - I've seen it hung up on a rock and support the whole rig!  (looks bent)  And somehow - it goes back to straight when she's off the rock.  It may be worth the investment :question:
The more I think about it the more I think I'm gonna go this way
For what I'm running it just seems to make sense
