ANTIROCK SWAY BAR END LINK ROD 8.5IN
Better off higher than parallel
Most jeeps can droop a tire a lot more than they can stuff it
Sent from my SM-G998U1 using Tapatalk
Mine are parallel with the frame
joe98tj said:
King of the Hill said:
The long plate should be horizontal at the mid point of your travel.
Well, looks like you already the instructions.. guess i'll go back to work
Thanks, I was looking for the instructions but didn't find them.  I read the parallel thing off one of the forums.
Terry I checked at work today - if 1/2x20 RH threaded rod (LH threaded rod is a unicorn here!) will work:
We have three foot lengths un-plated for $2.00 each my cost.
We have six foot lengths of plated for $6.00 each my cost.
Frank
Thanks Frank,  I'll let you know, for now I'm going to cut off  the threaded end of my dump U-Bolts for extensions.
It seams like a strange design for me to have the LH and RH threads.  It is one of those adjustments that you make once and never change again while mounted.
Well I chopped the threads off of one of the Dump find U-Bolts and added them to the links with couplers.  The height is set correct now and wheeled New Hartford last weekend with out any issues.
