Asking for Help
NomadJeep
Administrator
I have never gone completely out and asked for help on a board but I am extremely desperate....
I am at my wits end.... I am having so much trouble with my YJ, and I have no idea what to do next...
Anyone able to help me try and chase down a vibration in my rig... I have replaces every part thinkable and still,, I hit 50 mph and it is a humming vibe.....
Recent things done,,,
Dana 44, gears, detroit...
New HD rear drive shaft
front ujoints
front gears and locker,
front hub assembly////
I have been chasing this and now that I have taken everything apart several times, I am about to snap....
there are stories behind every part change,
but now I am thinking,
bent axleshaft
damaged locker (skibums)
something wrong with the front end,......
I need to get it off the ground and run the wheels and see what vibs/ or hums....
I am counting on this rig for Paragon, and if it aint ready, I cant go.....
Anyone? I will trailer it were ever....
The XJ could sleep outdoors for a while. Bring it over.
We'll start with putting a dial indicator on the axle shaft flanges and go from there. I've got plenty of large jack stands to do a dry-run in the air and watch things spin around.
Thanks guys,
tell me when,,, I will cancel shit to fit your schedule.... it can also stay if needed...
stupid thing is causing me to loose sleep
I can turn a wrench with the best of them.... but man, this is a friggin ghost....
I can drive it,
it is fine on back roads,,,, and you dont live that far away....
Monday after work? whenever,,, except Tuesday night....
Damon, I will make it right if it ends up being the locker. Are you running the same tire/wheel combo as before?
Well the story goes, I have not put in the uses shaft (thanks Marks) becuase there was still a vibe a higher speeds. So I was trying to chase that down... well it turns out that it is the brand new HD sahft from Tom Woods,, so they are sending me a new one....
