broken zerk
XJ-Maki
anyone have a good trick to remove them? The grease fitting on my front driveshaft is broken off flush.
I broke mine off a few weeks ago. ended up drilling it out and putting in a 3/8npt fitting. I'm sure a left handed drill bit will pull it right out. if not, seperate the shaft and push it through.
I have some easy-outs and it should come right out because they are soft metal. Come on over some evening and pick them up.
