beaker
I pulled my axle apart to replace the spider gears. It's a dana 35 in a cherokee. If you put new carrier bearings on do you need to re-setup your gears. I didn't think carrier bearings could look that bad and still work. If I sandblasted the races it might smooth them out a bit. Maybe a little 40 grit to help smooth them out. (I'm serious).
I driving it as the problem I just had that caused me to loose my spider gears was unrelated (too many neutral drops). Hopefully it will last until I can replace the axle or fix it.
