cooler1054
Anybody good at diagnosing CB problems, or knowledgeable about them
cooler1054 said:not sure what the problem is. I think it might be in the antenna system, the unit itself seems to work. It just seems not to work on and off
cooler1054 said:reception and transmitting come and go. unit power always works
cooler1054 said:There is no "noise". There is either nothing or radio traffic comes in clear. It seems that it is only working with close distances. The last time I Know for certain it works I was a couple hundred feet away from the person I was talking to. Is there someway to test the power the unit has.
tjcoastie20 said:yea its called an SWR meter. its used for matching an anntena to a radio so you don't burn the radio up
Erik S. said:Â Do you know what matching is, or is it a term you've heard and are regurgitatiing?
tjcoastie20 said:Erik S. said:Do you know what matching is, or is it a term you've heard and are regurgitatiing?
yes I know what matching is. I match all of my own radios. also I don't generally make posts regarding technical information I have not had experience with myself.![]()
 ÂErik S. said:No offense intended, so none should be taken.
