centering axle?
  • Thread starter Thread starter rocknerd
R
rocknerd
I'm installing an adjustable track bar, well, this morning (sat.) and I was wondering the best way to center the axle. Do I disconnect the track bar, center the axle, then measure for the length of the adjustable one? I'd like to put this thing on once. NOT BLOODY LIKELY
First start by putting it up on jack stands just behind the suspension mounts to let the suspension hang, pop off the tires, get a straight edge like a level.remove old track bar,insall new track bar.Place level on flat surface on brake rotor and measure the distance from the frame to the level.Adjust trackbar so both sides are the same.then when your done take a jack and move the front end up and down a few times then measure again.Should be all set,if not readjust as nesasary.Put the tires back on and go wheelin.There is more than one way to do this but I've found this way to be the most acurate.
Oh yeah,make sure you place level as close to the center of the rotor as posible not on the brake surface hope it helped.
