Especially if you have hard poly bushings. Being the OEM mounts are barely welded to the axle, it is always a good idea to re-weld or gusset/plate.
The reason harder POLY bushings are more troublesome is because the forward jarring motion will not give any play, so every time you hit a bump it pushes off them with no give.
[attachments are removed after 60 Days]
