B
BIG
OK, so in what may be the longest delay between ordering and installing parts:
BDS 3.5 lift
Hydro shocks
Currie front shackles
Currie rear Boomerang shackles
I figured I would do a simple test fit of bushings, sleeves, shackles and make sure everything was in order before I try and get moving on this long overdue mod. I find that with he currie CE-9040 fronts (ordered thru quadratec) test fit on the shackles that the spring wrap hits the center section on the shackle when I try to move it all the way front to back - moderate movement front and back is fine.... but it look close. Should I just send back and get another boomerang set so I will have em front and back - or should these be fine?
Oh, and any help with the lift would be nice............hint hint.
BDS 3.5 lift
Hydro shocks
