Z
Zaedock
Hi folks,
I'm looking for a bellhousing, flywheel, and clutch components to swap my Malibu's 350 into my SM420 equipped YJ which currently has a blown 2.5L.
Instead of rebuilding the 2.5L, it is more economical to do this.
In my search for forks, throwout bearings, pilot bushings, and such, what
year(s)/vehicles should I be getting parts for? My SM420 has the 4 11/16" bearing retainer hole, as most of you know. I plan to keep the hydraulic clutch and make a mount for a custom slave cylinder (what do you guys use???).
My Malibu currently has a TH350 with a 168 tooth flexplate and starter. Is there a 168 tooth flywheel so I can retain my starter or will it work with a 153 tooth?
I need to do this as cheaply as possible.
Any and all help would be greatly appreciated.
Joe
Joe
