CJ7 project
  • Thread starter Thread starter aafish
A
aafish
Did some testing on the jeep today,just got done with my SOA dana 60 swap and have to deal with the axle wrap issue,other than that things went better than I thought they would.I am looking for some input on the options for fixing the wrap problem.The jeep will be getting a small block/auto trans after I get the drivetrain set up the way I want so I think I probabaly need to build a link mount on the axle and run a traction bar? Any thoughts?
what size tires are you running and what type of jeep?
I have a small chevy with 38.5 swamper and it run spring under.
axle wrap, run a torque arm.  Just set up a leaf spring shackle to hold the front of the torque arm and use two rod ends to connect it to the axle so you can adjust your pinion angle.
It's true, sazw this thing runing and driving under it's own power. I think it's going to do pretty good on the RTI. :grinyes:
i run the M.O.R.E anti-wrap bar. works very well and its reasonably priced for what you get in the kit.
