Clutch Pedal
RobTJ
Ok, coming back from lunch I noticed that the clutch pedal was acting funny. When I'd push it in, it would be fine until it gets to a point where is almost feels like it's sticking. Then I would push through it, and it would be fine. The same thing would happen when I released it. :thinking:
I'm just trying to figure out if this is a simple problem with the pedal that I can fix with a bottle of spray silicone. Or do I have a BIGGER problem on my hands? :doh:
Oh no. It's done for. The fraggille bearing is gone and the whole jeep is worthless. It will cost more than it's worth to fix it.
Sell it to me for $50 and I'll take it off your hands.
Can you guess how much to drink I've had?
Really, check the pedal and see if you can see the hyd throwout bearing to see if they are both working properly. Otherwise, it's probably the bearing or the clutch. Master cylinder is probably good, though no guarantee's.
no PITA hydraulic throwout bearing on jeeps after 1990 I think....
