Cool New Toys
NomadJeep
Administrator
Thought I would start a thread that had some cool new stuff out on the market.  There is so much stuff coming out, it would be cool to keep an eye out if you saw something.
New from BDS plain basic sway bar disco:
  CLICK HERE
BombProof Block Brackets for XJ, TJ & YJ 4.0L
The factory block brackets are retained w/ 3 bolts, We have seen many cases where the bolts come loose or break causing the engine to fall. Sometimes this will also damage the block ( Threaded Bosses ) . We have come up with a replacement bracket that will bolt on using 7-8 existing threaded holes on the side of the block.
