Hi folks,
I’ve been thinking about doing a disk break conversion for the rear axle but I’m not sure it’s going to really help. With the 4:56 gears the torque of the drive line is so intense in 4 low that the breaks are barely able to hold the driveline back. Going down hill it is even worse especially with the 3 speed auto because there is no help from the engine to slow the drive line down.
Here is the kit I’ve been looking at. This is the cheapest price I could find and it has free shipping.
http://northridge4x4.com/products.php?id=677
I’ve been trying to read thru the install instructions but it all seems like alien speak to me.
Here is the pdf link.
http://www.teraflx.com/installsheets/DBK_install.pdf
It seems to me I will have to replace the hard lines on the axle.
Hodgie at work also noted that the kit comes with bango bolts and he said they kind of suck. I wouldn’t know the difference but he’s a big time gear head so I’ll take his word that they are not that great.
It seems to me I will have to replace the hard lines on the axle too.
Notice it make no reference to how short the lines need to be.
Also there is no mention of having to change anything at the master cylinder or at the TJ’s combination valve.
Stu has a write up on swapping in the combination valve from a ZJ. But he never mentions if it really made any difference.
Here is his write up.
http://www.stu-offroad.com/suspension/d44brake/bc-6.htm.
Oh well…those are my thoughts.
Here are a couple more links that I’ve found to do things on the cheap.
http://www.stu-offroad.com/suspension/d35disc/d35-1.htm
http://www.jeepsunlimited.com/forums/showthread.php?t=415635&page=1&pp=20
Any thoughts you may have would be appreciated. Gotta run to work now! Have a great day!
T.
25. Connect the hard brake line to the soft brake lines, and bleed the brakes. Start with the passenger side first, then proceed to the driver’s side. Note: You will need to purchase shorter metal brake lines from an automotive parts supplier.
T.
