This article is from JP magazine.
http://www.jpmagazine.com/featuredvehicles/154_1110_50_ways_to_lighten_your_jeep/viewall.html
50 Ways To Lighten Your Jeep
Jenny Craig Jeep
From the October, 2011 issue of Jp
By Christian Hazel
Photography by JP Staff
Whether it's that spare tire you're carrying around behind your belt buckle or a bunch of unnecessary trinkets and doo dads on, in, or around your Jeep, extra weight kills performance, increases the likelihood of breakage, and requires more energy and effort to move around. Shedding unnecessary poundage from your Jeep will make your engine feel more powerful, help your drivetrain components live longer, and allow your suspension to react more quickly. We came up with fifty things you can do to lighten your Jeep. Some may not be applicable or realistic for everybody. And some may not seem like they?d make a ton of difference. But as we demonstrated in ?Skinny-Time!? on page 84 of this issue, the cumulative result of just a few of these mods can really make a difference.
Jenny Craig Jeep Jeep Front Three Quarter
Stock Bumpers
Stock bumpers are light. If you want a bit more beef, you can use some 1/8-inch or even 14- or 16-gauge steel to box your factory channel bumper to better resist twisting and damage.
Jenny Craig Jeep Jeep Rear Three Quarter
Rear Bumperless
Rear-end collisions aside, most Wranglers can get by without a rear bumper on the trail. Or, for older Wranglers and CJs, keep the factory bumperettes. They?re much lighter than a full factory or aftermarket rear bumper.
Jenny Craig Jeep Third Member
Ford Light
Thanks to its strong presence in motorsports for decades, there are several really cool aftermarket lightweight components for the Ford 9-inch such as aluminum centersections, bearing retainers, and even spools. Adding disc brakes to these parts and using 31-spline alloy axleshafts can get you a really strong rear end that weighs in at only a couple hundred pounds.
Aluminum Wheels
Steel wheels are cheap, but aluminum wheels are much lighter. Not only will they decrease the overall weight of your Jeep, but your acceleration and braking performance will increase because it takes less energy to start and stop them spinning.
Jenny Craig Jeep Rear Axle
Ditched Dana
For its weight, the Ford 9-inch trounces any comparable Dana 35 or Dana 44 axle in strength. And upgrading the 31-spline shafts to aftermarket 35-spline units puts it in the same ilk as the burly (and heavy) Dana 60.
Spareless
If you have a patch kit and a source of onboard air, leaving the spare tire at home can save up to or over 100 pounds depending on your tire size. If you have beadlocks or rims that can be dismantled in the field, a tire tube is also a great alternative.
Jenny Craig Jeep Jeep Wrangler Passenger Side Front Three Quarter
Doorless
Ditching the factory steel full- or half-doors from your Wrangler or CJ saves a lot of weight. If you must have protection from the wind and elements, a set of aftermarket soft doors will get the job done at a fraction of the weight.
Jenny Craig Jeep Dana Axles
Dinky Danas
Dana 60 and Dana 70 1-ton axles are super strong, but they?re heavy as sin. If your tire size and wheeling style allow it, retaining your stock axles (Dana 30, Dana 35, or Dana 44) can save you several hundred pounds, even if you bolster them with larger, slightly heavier axleshafts.
Jenny Craig Jeep Cargo Area
Seatless
If you don?t carry rear-seat passengers then why do you need a rear seat? They?re pretty heavy. Even if you?re not wheeling a Wrangler or CJ, full-size, Cherokee, and others can ditch the rear seat and belts for a big bump in weight saving.
Jenny Craig Jeep Tool Box
Smart Tools
Carry only those tools and spares you need. Why bother shedding ounces here and there if you?re just gonna bring along 50 pounds in spare parts and unnecessary tools. If you don?t have any 5⁄8-inch bolts on your vehicle, why bring a 5⁄8-inch socket or wrench? Pack smarter, not heavier.
Jenny Craig Jeep Rear Suspension
Improvised Armor
This is something we suggested in ?Skid-Free? (May ?09) where you create laminate armor by welding lighter-gauge material to your existing skid plates. It?s an effective alternative if extreme use is not in your vehicle?s repertoire. In our story, we used two factory 14-gauge Wrangler fuel tank skids to create a lightweight 1⁄8-inch skid that will support the weight of the vehicle.
Jenny Craig Jeep Jeep Front Bumper
Bumper Material
Who says your bumpers need to be heavy steel. There are several companies making Jeep bumpers in aluminum and even fiberglass. These offer a surprising deal of strength in a bantam-weight package.
Jenny Craig Jeep Jeep On Its Side
Topless
A Wrangler or CJ hard top weighs a bunch. Even the factory soft top and the associated hardware isn?t exactly featherweight. What is featherweight is a simple bikini top. It?ll keep the sun off your head and won?t tip the scales against you.
Other-World Armor
Aluminum armor is roughly half the weight of its steel counterpart with very few drawbacks. If you?re a hardcore basher and don?t want to go full-aluminum armor, consider strategic use of aluminum armor for less-vulnerable places like your rear corner guards or even tube fenders. Or for even lighter protection, HDPE plastic can be utilized in strategic locations.
Jenny Craig Jeep Jeep Windshield
Glassless
Glass is heavy and breakable. Polycarbonate is light and flexible. To us it?s a win-win: lighter weight in a pliable package that won?t shatter with any rock hits or tree impact. Higher-end units like this PolyShield windshield (polyshields.com) resists scratching as well as any glass windshield.
Jenny Craig Jeep Tires
Light Tires
Almost all tires for 16-, 17-, and 20-inch rims are Load Range D or E. These higher load capacity tires not only weigh more than Load Range C tires, their heavier sidewalls don?t flex as well or ride as smoothly on a lightweight Jeep. Making sure you?re running a Load Range C tire will not only give you?re a softer on-road ride, but will generally get you a lighter tire in the bargain.
Jenny Craig Jeep Jeep Engine
Rockin? the Four
If you "settled? on a four-cylinder Jeep rather than swapping in a heavy six- or eight-cylinder, consider keeping your lightweight four-popper and gaining performance through gearing and weight shedding. With proper gearing and careful attention paid to weight, a four-cylinder Jeep can give more than adequate performance without dramatically tipping the scales.
Jenny Craig Jeep Fiberglass Jeep Front Three Quarter
No Steel
Replacing your steel hood or fenders with lighter fiberglass parts will free up a lot of weight over the front tires. Or, if you?re building a more extreme vehicle, consider a high-clearance one-piece fiberglass hood with integrated fenders like this one from Chris Durham Motorsports (chrisdurham.wordpress.com).
Jenny Craig Jeep Flywheel
Flyweight Flywheel
For vehicles with manual transmissions, a heavy flywheel can impart a lot of inertia that will keep your engine chugging at low rpms, but with modern computer-controlled injection systems, it?s not always necessary. Going to a lighter flywheel will not only shed 10-30 pounds from your vehicle, but will make your engine rev quicker.
Jenny Craig Jeep Jeep Interior
Gutted
Carpet only gets wet and dirty and if you?re going topless you?re not worried about sound levels. Ditching your factory carpet and sound deadening not only frees up weight, but makes messy mud and dirt cleanup quick and easy. Spray-on liner material is popular, but heavy and impossible to weld on or under. Keep it paint for the minimum in weight and maximum in versatility.
Paragraphimage
Spring Seating
Most aftermarket suspension seats are not only more comfortable than stock seats during severe off-roading, they?re usually much lighter as well. This is especially true when compared with factory power leather seats, but even pedestrian vinyl buckets can be swapped out for a decent weight savings.
Jenny Craig Jeep Winch Plate
Winch Plate Weight
Using a winch plate rather than a full winch bumper will get your recovery gear mounted to your framerails at a fraction of the heft. And if there isn?t a dedicated part number for your application, you can usually modify a universal mount to work in several applications. Or, better yet, use a removable hitch mount and leave the winch behind when you don?t foresee a need for it.
Jenny Craig Jeep Heat Removed
Heat No More
For most dedicated trail rigs, the factory heater/defroster ducting is dead weight that takes up space. This is especially true if you drop down or remove your windshield. Removing your electric blower motor, heater core, ducting, and related components can shed enough to offset the weight of some extra spares and tools.
Jenny Craig Jeep Transfer Case
NP to the NV
Back in the day everybody thought you needed a honkin? NP205 or other huge iron-case, all-gear T-case to get the job done. But the reality is that most aluminum- or magnesium-case chain-drive T-cases can be built just as strong at a fraction of the weight.
Jenny Craig Jeep Ac Compressor
Compressor Ejection
Most older A/C systems work inefficiently or not at all. And what are you anyway; a wuss? Chuck that A/C system in the recycling and you?ll save as much as 100 pounds in compressor, brackets, hoses, condenser, and other related components.
Jenny Craig Jeep Steering Wheel
Wheel Weight
Not those wheels; your steering wheel. It?s a bit compulsive, but in a worst-case scenario, switching to a lightweight aftermarket steering wheel can see a 10 pound-or-better drop in weight compared with the bulky factory offering.
Synthetic Winching
Swapping your steel cable out for a synthetic winch rope and going from a steel roller to an aluminum Hawse fairlead can drop between 20-30 pounds (depending on cable and rope length).
Jenny Craig Jeep Plastic Headlights
Plastic Fantastic
Okay, this is taking things a bit far, but even your headlights can be fodder for weight weenies. If you need new headlights anyway, swapping from factory-type all-glass headlamps to aftermarket units with polycarbonate lenses and plastic bodies will waste some weight away.
Jenny Craig Jeep Transmissions
Transmission Temptations
Sure, adding a 3/4- or 1-ton cast-iron four-speed or heavy NV4500 five-speed may be tempting, but is it really necessary? Often, the flyweight cast-iron three-speed or a medium-duty aluminum-case five-speed will get the job done at about half the weight of the bigger stuff.
Jenny Craig Jeep Fuel Cell
Dimpled Holes
Drilling holes in mounting brackets, framerails, and other components throughout your vehicle can drop a bit of weight, but the holes could possibly affect strength. However, running a dimple die over the hole after it is cut will add a contoured flare that not only looks good, but increases strength and rigidity in the bargain.
Jenny Craig Jeep Engine On Dyno
Head Games
Upgrading to aluminum cylinder head(s) on your I-6 or V-8 engine is an all-around great upgrade. Not only will you get better performance, but you?ll cut the weight of your head(s) in half, generally saving between 20-50 pounds.
Jenny Craig Jeep Exhaust Removal
Flow Go
Factory muffler and exhaust pipe systems are not only restrictive, but are usually insanely heavy. You won?t save a ton of weight in free-flowing aftermarket exhaust pipes, but you will save considerable weight in swapping to an aftermarket crimped-case or fully-welded muffler.
Jenny Craig Jeep Headers
Manifold Monsters
Almost all V-8s and most inline four- and six-cylinder engines came factory-equipped with heavy cast-iron exhaust manifolds. Swapping to aftermarket tubular headers can not only free up power, but sheds a ton of weight from the front of your vehicle.
Jenny Craig Jeep Tailgate Removed
Open-Ended
If you?re wheeling you should have everything strapped down tightly and securely. So, if that?s the case why would you need a heavy tailgate? Wrangler tailgates are kinda heavy, but FSJ SUV and pickup tailgates are downright porky. Either way, ditch it for a big boost in lightness.
Jenny Craig Jeep Radiator With Electric Fan
Radiator Roundup
Aside from the weight savings to be had by using an all-aluminum radiator over an all-copper/brass radiator, you can lighten other cooling system components. Swapping from a bulky clutch-activated mechanical fan to electric and going from a cast iron to aluminum water pump will shed a few crucial pounds from your equation.
Jenny Craig Jeep Battery Mounted
Battery Basics
Factory-spec wet-cell batteries are inexpensive and can offer an attractive life span. However, most aren?t exactly compact and almost none are lightweight. Upgrading to a dry-cell race battery like an Odyssey (odysseybattery.com) can get you more power in a smaller, lighter package. Lithium-ion batteries are even smaller, lighter, and more powerful, but at this point in time they are cost prohibitive for all but the deepest pockets.
Jenny Craig Jeep Track Bar Removal
Trackless
This is most true for YJs, but applies to some FSJ Wagoneers and other models as well. If you have a properly set up leaf-spring suspension and don?t drive like a total moron, there?s really no need for front or rear track bars. Ditch ?em, along with their mounting brackets. Factory track bars aren?t exactly light.
Jenny Craig Jeep Roll Cage
Chromoly Countdown
Using HREW (hot rolled electrically welded) tubing may be cost-effective, but chromoly tubing has a much higher tensile strength. That means you can run thinner, lighter chromoly tubing with no penalty in weight. Chromoly does present some special issues when working with it, though. Careful attention must be paid to heat-affecting during welding, and ideally the cage should be heat treated after construction.
Jenny Craig Jeep Jeep On Lift
Half-glassed
We?ve already mentioned using fiberglass hoods and fenders, but a complete replacement fiberglass body tub will shed some weight over an all-steel stock tub. Considering most vintage tubs are full of Bondo, which gets really heavy, ditching a poorly-patched stock steel tub can make the weight savings even more dramatic.
Groovy Tires
It?s something the monster truck and mud bogging community has long known about, but cutting and grooving heavy mud tires not only increases bite in certain off-road terrain, but can offer a massive weight savings. As an added bonus, the lightened tires will spin up to speed faster and flex better at lower pressures.
Jenny Craig Jeep Corvette Engine
All-Aluminum
We mentioned the weight savings in going with aluminum cylinder heads, but if you?re doing a whole engine swap, using an all-aluminum V-8 engine such as the GM 5.7L LS1, 6.0L LS2, 6.2L LS3, or even 5.3L LC9 can save you around 100 pounds compared with an iron block/aluminum head engine. Other contenders are all-aluminum V-6 or even old-school Rover or Buick 215 V-8 engines.
Jenny Craig Jeep Link Bar Mounted
Holy Bolts!
Ever held a box of bolts in your hand? Not exactly light, is it? You can order special hollow chromoly or titanium bolts through McMaster-Carr (mcmastercarr.com) and other racing-specific vendors you can find on the Internet. They may not shed a lot of pounds from your vehicle, but they certainly will shed dollars from your wallet!
Jenny Craig Jeep Intake Manifold
Take the Intake
Got an AMC or other brand V-8 in your Jeep? Still got that boat anchor cast-iron intake? Swapping to an aftermarket aluminum intake manifold will not only free up horsepower and torque, but can improve mileage and shed 25-30 pounds from the front of your vehicle.
Barless
Again, with careful driving there?s not much reason to retain the factory sway bar(s) on a leaf-sprung vehicle. And even if you?re running coils or coilovers, you can probably get by with only one sway bar in the front or rear of your vehicle.
Jenny Craig Jeep Steering Box
Tractor Steering
Most hardcore off-road rigs spend most of the time on the trail and little, if any, on the street. Going to a full-hydro steering system will replace the heavy steering box with a relatively light orbital valve and will do away the need for a heavy drag link and track bar. Be warned, on-road steering may be twitchy and even scary, so keep it in the dirt.
Jenny Craig Jeep Disc Brake
Brake the Bank
When looking for performance from weight savings, any pound dropped off your rotating components, especially at the wheels, will have a much more dramatic effect than elsewhere. Lightweight aluminum calipers are svelter than cast-iron factory parts and almost always weight less. The drilled and vented rotor with lightweight aluminum hat will not only run cooler, but have much less rotational weight than the stock parts.
Jenny Craig Jeep Master Cylinders
Bump the Booster
We see a lot of people adding complicated hydroboost setups or converting to power brake applications. For Jeeps running automatic transmissions with low-stall converters and extreme low-range gearsets it?s sometimes necessary. But for most other applications, a properly set up manual brake system will perform more than adequately. Even running twin 7⁄8-inch bore master cylinders, this Wilwood braking system (wilwood.com) is lighter than a single factory cast-iron master cylinder.
Jenny Craig Third Members
Lightened Gears
From our drag racing days, we remember a certain factory alloy diff cover all the GM 12-bolt guys were clamoring for ?cause it was a couple ounces lighter than the factory cover. So, it shouldn?t be surprising that you can buy highly lightened gearsets, such as this circle-track Ford 9-inch. We?ve beaten these Richmond gears off-road for years with no failure.
Jenny Craig Jeep Unit Bearings
Unhated Unitbearing
Building a custom axle assembly for a lightweight Jeep? Using Ford unitbearing knuckles and hubs can net you a considerable weight savings over a standard Dana-style hub/spindle setup without giving up the ability to run locking hubs. You can take it a step further by replacing the factory F-350/F-450 Dana 60 knuckle with an all-aluminum version from Currie Enterprises (currieenterprises.com).
Jenny Craig Jeep Chassis
Factory Frame
Most factory Jeep frames are constructed from 1⁄8-inch channel steel. If left open cracks can form, so most builders tend to go straight to a thick 3⁄16-inch custom-built or aftermarket frame. For some cost and weight savings at the expense of a lot of work, you can plate in your stock frame with 1⁄8-inch steel to really bump the strength and survivability. Adding dimple-died holes to the plate will lighten it even more.
Jenny Craig Jeep
By Christian Hazel
Stock Bumpers
Rear Bumperless
Ford Light
Aluminum Wheels
Ditched Dana
Spareless
Doorless
Dinky Danas
Seatless
Smart Tools
Improvised Armor
Bumper Material
Topless
Other-World Armor
Glassless
Light Tires
Rockin? the Four
No Steel
Flyweight Flywheel
Gutted
Paragraphimage
Spring Seating
Winch Plate Weight
Heat No More
NP to the NV
Compressor Ejection
Wheel Weight
Synthetic Winching
Plastic Fantastic
Dimpled Holes
Head Games
Flow Go
Manifold Monsters
Open-Ended
Radiator Roundup
Battery Basics
Trackless
Chromoly Countdown
Half-glassed
Groovy Tires
All-Aluminum
Holy Bolts!
Take the Intake
Barless
Tractor Steering
Brake the Bank
Bump the Booster
Lightened Gears
Unhated Unitbearing
Factory Frame
