I have a set of YJ half doors that I picked up a while ago. I went to put them on for the first time, and they don’t exactly align up. When the door is put on, the bottom hinge sits flat, but the top hinge there is a 1/4" gap. The door should actually go a 1/4 down being the striker does not line up. It does not appear to be bent anywhere, but is the hinge plate on the door adjustable? Can it be loosened and just the bottom hinge moved, that appears to be the only one throwing the alignment off.
