RedJeepster1
I have a question about the drum brakes on Emily’s XJ. I took them apart last week to figure out why they weren’t working too well and found a leaky seal, so I replaced both wheel bearings and seals and then had to replace the brakes due to everything being soaked in oil. I had a used but basically new set under the bench, so I decided to use those. As you can see, all the parts were almost new. They were take offs from someone else’s Jeep I worked on. He had just bought it and wanted all new brakes, didn’t care that the rear was almost new already.
My question is regarding how the brakes are now acting. The drivers side is working great. Adjusted until it started to drag and it works fine. Passenger side drags on half and doesn’t on the other. If I adjust more it just gets stuck and then free spins. Same spots every rotation. When driving and I hit the brakes I can feel and hear it coming in and out. Working and then not working. What would cause that? Maybe that wheel cylinder isn’t working and it’s staying loose in there when I hit the brakes? I didn’t test that each was working. I should have… but didn’t expect to have issues. Only did the brakes because they were soaked with oil.
