if your oil pressure was really zero, your lifters would start ticking and the bottom end would start to knock. The factory jeep gauges do not read below 10 psi. My last cherokee had squat for oil pressure. Watching the gauge. The oil pressure would slowly drop once the engine idled down and it would hit the ~10 psi point and drop to zero.
As far as startup wrapping, slick 50 is designed to get money from your wallet, nothing else. Those ptfe particles will get caught where ever they can. They'll plate you oil filter paper nicely.
Try a better oil, I had a car lose all oil pressure a few weeks after going to a speedy place. Their oil was so cheap it broke down in weeks. The stuff poured out like water. Put new oil in, no more problems.
