Ford 8.8 Complete TJ Axle Kit
NickMaida
This is everything you need to build a Ford 8.8 for a Jeep TJ/XJ. ¼” brackets, 4.56 Gears, 31 spline, ARB air locker, 5x4.5 bolt pattern, 59 5/8 WMS.
Got the axle from Tom’s Auto in Bristol, cut the OEM brackets off and set up the gears. That is where it sits now. Everything listed below was purchased new back in 2016 (I provide no warranty). Its about $2100 worth of parts (oh well).
31 Spline Disc Brake Ford 8.8 (59 5/8 WMS, 5x4.5 Bolt Pattern)
SOLID nodular diff cover
OEM 8.8 loaded brake calipers + rotors
Jeep ZJ/TJ ebrake cables
ECGS Rear Brake Line Kit for Jeep TJ, XJ, ZJ
ARB 31 spline Air locker
Yukon Master Install Kit + lubelocker
Yukon 4.56 gears
Barnes - B4W0061K TJ Rear Axle Upper Control Arm and Track Bar Brackets
Undercover Fabworks - UCF423 - UCF Jeep TJ Rear Coil Spring Mounts (axle only)
Artec TJ8804 TJ 8.8 Swap kit OEM Shock Mounts (Pair)
Artec TJ8805 TJ 8.8 Swap kit OEM LCA brackets (Pair)
Artec TJ8802 TJ 8.8 Swap kit OEM Sway Bar Brackets (Pair)
12” x 7” aluminum air tank + pressure regulator (compressor not included)
I also have an 8.8 Artec modular truss for sale.
Between myself and a previous NEJeep member, this axle has sat on workbenches for 6 years. Someone needs to finish it.
Asking $1300
Saw your FB post. Great deal here, I'd jump if i hadn't already swapped in a 44, your price is insanely low.
Eric
99 TJ
