C cowboyupdan Guest Dec 29, 2005 #1 with a new h/p axle in my tj my drive shaft is toooooo long and pinched :swear_mad: should i cut it down :question:
beaker Active member Dec 30, 2005 #2 Measure what you need. Maybe a drive shaft from a cherokee (there's a couple different lengths) or older wrangler will work.
DonnyG New member Dec 30, 2005 #3 Will that be an issue in an XJ as well? Hopefully going that route after my birthday. $$$
C cowboyupdan Guest Dec 30, 2005 #4 i'll measure it sun when i go to the garage with a hangover :twisted:gotta work that day
beaker Active member Jan 1, 2006 #5 Any change in style of axle will probably result in needing a new drive shaft Both of you should try pulling drive shafts from cherokee's with the same transmision / transfer case combo's that you have. Just ones for 87-99?
