JeepinMaxx
I swapped a 4.0L in my 90YJ a while back. On the fuel rail - there is a 5/16" 'return' line coming off the rail - where is that supposed to go? My carbed engine ran that back to the tank. So I assumed that's where it should go. Am I wrong? I was checking out the MPI conversion instructions and they mentioned that the 'return hard line' would no longer be used. Now i'm worried I have it hooked up wrong ( the YJ has run 2+ years like this) BUT, if I stall- it has trouble starting back up (feels like a flooded carb used to) Also - when I'm on a low tank - when I pop the cap to fuel up - it's under pressure. Looking for some input...
