JeepinMaxx
Well - I filled up today and I smelled gas fumes. A puddle was forming under the tank! Apparently my 'exhaust modification' from the carnage at Mahem caused a problem. I cut the mangled tailpipe off at the muffler and as a temporary fix I just clamped a 7" long down pipe to it. It looks like the hot exhaust melted the plastic tank about 1/2 way up. Now I have a stream of gas coming out (1/8th inch stream- smaller than taking a leak - pun intended!). This started at 5PM and its still going at 10:30PM (Damn 20 gallon tank and $2.49/gallon of Super going down the drain!). Anyway... anyone ever use one of the epoxy fixes for a leaking plastic tank? Like JB Weld? If so - is it a permanent fix? Thanks in advance for your input...
