R
RidinRyan
I have my dana 30 from my TJ with 3.07s and i was offered a 4.10 ring and pinion out of a 1995 yj high pinion d30. Can i just open the cover, swap the gears and be done? there was some question to the "pinion is higher and the ring remains in the same place, thus the cut is different" and other things but i figured id just ask you guys. SO, can i swap them or will they not work? thanks
