getting vibrations
  • Thread starter Thread starter Moose
M
Moose
i get a vibration or almost a thud thud kinda sound when let out the clutch from 0-5 mph... it then goes away i have already changed the rear control arms and rear sway links.. i know my skid plate is dinged up. Is this putting my trans outa whack making the vib?
lol didnt you see me at four play in that bangin off road toyota corrola??? did you see the rubber on that monster.. 4cyl off road monster ...
Moose it could be anything...
But I would really have to drive it, and look it over...
Could be clutch chatter
Could be the T-case slapping the belly pan (if it was that bent)
Could be tires,
Could be U-joints
Could be front d-shaft
Could be F-Tcase output bearing.
Could be the exhaust hitting something...
The list goes on... however most of those things dont fit the slight info you are giving us, (vibe and noise) but you can still get the idea....
Until we really take a look, I cant really say.. (sort of vague) if I get free at the Rally, and Pete has not solved it, I will take a looky for yaa...
