DonnyG
Gonna be putting in new 4.5" front springs this weekend. As well as the Rusty's adjustable trackbar. Looking for a good alignment shop that will be able to correctly adjust the track bar for the appropriate lift levels. Also, how much difference is there using the stock upper control arms and fixed 3" length lower arms from BDS? Will it be ok to have them at a 4.5" lift, or should I really shell out the xtra clams for the adjustable uppers? In the above XJ spec sheet, it gives the length for the arms, is that for uppers and lowers or just uppers? Little help please. Looking for a shop as close to New London as possible. After I put in the 3" lift, the front end was real squirlley on the way to the alignment shop. (they also gave me a lot of sh*t for lifting it) they said if I go any higher, they won't be able to align it. :blabla:
Thanks,
Donny
Thanks,
Donny
