HELP!!!!!
  • Thread starter Thread starter Mandy
M
Mandy
I need some help on this.  I was driving down rt. 9 doing about 65 mph and all of a sudden all my gages went to zero and my airbag light turned on, its happend a few times now.  Doe's anyone know whats going on?
Rachel's old TJ did this.  There was some corroding of the contacts that connected the instrument cluster.
Thank you Ken, but I have no idea what you are talking about so I'll have Donny look at that for me, thank you again.
Tell him to make sure you have a good ground in that cluster.  Jeep is notorious for trouble with the instrument cluster dropping the ground.
my buddys 98 tj did that  he pulled the cluster out  and cleanded the contacts on the wire harness and gave the pins a lil twist. no problems for the last few years    have donny call me if he needs more info
They are 100% Mandy
Need me to take care of it, let me know...
You take of me, I take care of you.... etc....
Ohh, ahh Hi Donny.... ahh, <hypnotizing> "you did not read any of that wooooo"
take a look here.. pics
http://65.42.106.152/forums/showthread.php?t=674479&highlight=speedo
and
This should help....
NO: 08-15-99
SUBJECT: Erratic, Intermittent Cluster Operation/Intermittent Air Bag Warning light.
DATE: May 21, 1999
OVERVIEW:
This bulletin involves installing a repair harness containing a revised instrument cluster connector.
SYMPTOM/CONDITION:
Some vehicles may exhibit an intermittent illumination of the air bag warning light or an intermittent tachometer or speedometer drop out. An Airbag Electronic Control Module (AECM) fault code -"No Cluster CCD BUS " message will be present.
DIAGNOSIS:
This condition is caused by minor oxidation of the BUS circuit terminals at the instrument cluster connector. Electrical terminals will show signs of oxidation, which will appear as darkened lines or marks on the cluster male terminals. These often appear as gray or black marks rather than the appearance of oxidation or corrosion usually associated with higher current carrying circuits. THIS TECHNICAL SERVICE BULLETIN WILL NOT ADDRESS FUEL OR OIL PRESSURE GAUGE ISSUES.
PARTS REQUIRED:
Part No. Description
105016261AA Cluster Connector Patch Harness
104856975 Electric Contact Cleaner
204778570 Heat Shrink Tubing
REPAIR PROCEDURE:
Disconnect the negative battery cable.
Remove the instrument cluster using the procedures outlined in the appropriate servicemanual.
Inspect the male terminals of pins 1 & 2 on the instrument cluster connector labeled CNB. The oxidation will appear as gray or black lines or marks on the terminals. If any signs of oxidation are present, remove them by gently scraping the terminals with a small flat bladed screw driver until the oxidation is gone. Use of a magnifying glass may be helpful. Use caution when performing this operation. Do not apply excessive force to the terminals to avoid bending them or damaging the cluster or terminals. Do not use a sharp tool, knife or sand paper, which could remove the protective plating from the terminals. Do not use any cleaner other than p/n 04856975. Other chemical cleaners could damage the instrument cluster.
Clean the male terminals with Electrical Contact cleaner, p/n 04856975. Apply the cleaner sparingly holding the cluster with the connector facing down to avoid excessive amount of cleaner from entering the cluster.
Remove the green cluster connector from the bracket.
Using wire cutters, remove the instrument cluster harness connector from the harness. Remove only the connector containing the BUS circuit This connector is labeled CBA on the cluster. Cut the wires as close to the insulator as possible.
The new connector must be soldered onto the harness. This operation requires a technician who is skilled at soldering to avoid a cold solder joint. Position the harness and align the wires with the patch harness, matching the color codes match the main wire colors. NOTE: THE XJ INSTRUMENT PANEL CONTAINS ONE MORE CIRCUIT IN THIS CONNECTOR THAN THE TJ. CUT THE UNUSED WIRE CLOSE TO THE CONNECTOR ON TJ MODELS.
Stagger cut the main harness and patch harness wires so that the solder joints will be 1/2 inch apart. Remove 1/2 inch of insulation from the wires. The new harness will have a dark blue with no tracer. This will mate with a dark blue wire with a green tracer on TJ and with a dark blue wire with a white tracer on XJ.
Slide a piece of heat shrink tubing over the wires and twist the wires together for each respective circuit.
Solder each circuit using rosin core solder. Be sure to heat the wire enough to allow the solder to melt when it comes in contact with wire. Do not use acid core solder.
Position the heat shrink tubing over the solder joints and shrink the tubing using a heat gun.
Install the connector to the bracket.
Install the instrument cluster.
Connect the battery cable.
Verify correct operation of the cluster.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Op. No.Time08-90-90-910.6 Hrs.
FAILURE CODE:
CodeDescriptionP8New Part
well Zach arebt you just a plethoura of knowledge!!! :rotflmao: :rotflmao:
ahh many years of being online and on the differant forums, you get to see and learn a lot.
Anybody have a wiring diagram I can print out?
And Damon, your Jedi mind tricks have no effect on me!!!!  I know what you're up to!!!! :mrgreen:
Thank you guys for all you input, its very helpfull and I will have Donny look at it on friday if he has time, other wise Damon I will take you up on that offer :wink:
