G
ghiradelli777
so i was driving around town the other day and i didnt feel that the truck had any pep and it was pulling to the right a bit, so i pulled over after about 15 minutes of driving....and found out my tires was smoking like carzy...
well it wasnt the tire, it was the brakes.....so i let them cool down..bad idea :disagree:
they stcuk to the rotor and it was hard to get going again so after i got the truck moving again i drove slowly towards home...
you can see where this is going i think.....
i then started to pick up speed becasue the brakes felt looser so i thought it might have unsiezed finally...wrong again... :swear_mad:
i decided to pull into a service station to see if i could use a jack to take the wheel off and look at the damage, as i walked around the side of the jeep, i could see FLAMES shooting out of the brake pads and caliper.....the guy in the station used a soda can and my iced tea bottle to extinguish the flames.....then we got the caliper cooled down by sticking a huge block of ice on it.... :swear_mad:
then 10 minutes later we took apart the brakes and saw the damage....clamped the brake line and i drove home using half my front brakes...
now i am in the garage...need to fix them...what part need to be check about lines, pads and rotor and calipers?
