Jk Axles, gas tank, driveshaft and 37s on beadlocks.
2010JunKU
Member
I have the factory rear Dana 44 rear with a matching front Rubicon axle out of my jeep available. The front needs a little work but nothing horrible. 2000 rear 2500 front.  They are complete rotor to rotor steering and track bars.
Tires are 37" Maxxis RZRs I bought new on AEV Borah I bought used.  Less than 5k one tire is a spare only as I had to pactch a sidewall 2500
JKU gas tank, factory skid and Barnes skid. Not fuel pump module. 500
Front 1310 extreme duty Adams drive shaft and t case yoke.  300
Located in Southington, CT. I  Have a machine to load the heavy stuff
Sent from my Pixel 6 Pro using Tapatalk
Looks like+4mm?
Stuffs pretty hard with 35s. Not sure if the extra ground clearance rub is worth loosing up travel squeeze. Not to mention I’m thinking if I do 4.88s instead of 5.13s with 37 road tires and 35 trail will be a good combo.
:sign_hijack: sorry bud  :redface:
