Horn
We've been borrowing my parent's as needed and it's time to invest in our own.
The one we used this storm was a Honda EU2200. It ran our basement freezer, kitchen 'fridge, a couple of lights and fans. On the pro side is used very little gas, especially running in eco mode. On the con side it was just barely enough to do what we needed. As long as both appliances with compressors weren't trying to start up at the same time it was fine, but we had it at its limit. It was a fine emergency setup and 2 of them can be run in parallel. But, it is also on the high end price wise so getting 2 would be out of our range when we could just buy 1 larger unit.
It would have been nice to be able to run our 10,000 BTU window AC unit a few times.
I'm thinking we could use something 4000W or more, mostly because of adding in the possibility of AC. Looks like a lot of
common units around are higher than that anyway.
Was still thinking along the lines of running extension cords etc, hadn't really seriously considered a transfer switch or learned much about it, though from what I understand it might allow us to run our hot water heater. I'm assuming that also means going to a larger unit, which is probably more than we need.
Just at the beginning of the research process.
Any words of wisdom, things that work well for you or to avoid?
The one we used this time beat the hell out of the old Tucumseh powered unit they had before this.
