libby 3.7
massxj
Moderator
guy at my Buddy's shop has a Libby thats getting antifreeze in cyl 4. has anyone heard of any common problems with this motor as far as coolant in the cylinders
3.7 is a six cylinder the 4 cylinders had a 2.4 liter 150 horse. Could be a many things, check the compression on the cylinders to begin with, this will at least tell you if you have a head gasket or head problem. Find out if it has over heated resently.
blah blah blah
Hes not saying its a 4 cyl he was saying its getting coolant in the number 4 cylinder.
Haven't heard to much about those motors or problems with them.
jon
i pulled the intake off and its air only no water jackets. must be the head or gasket. compresion test is good as  well as a leak down test
