B
BIG
94 YJ 4 Cyll -
Replaced the temp sensor and got the gauge working again - and now see that he gauge runs up to 210 - then to about 235 and then back to 210 and then back to 235.... not jumping around, just a slow climb and then falls back to normal at 210 and then it goes again and again and again? Tossed in a new thermostat, and it did not fix the problem!!! Where next? Fan Clutch, head gasket - I am at a loss. Any thoughts on what it might be would be and how to check would be appreciated.
I only mention the fan clutch as it was easy to spin when it was cold when I replaced the thermostat... I thought that when cold it should be harder to spin...
Thanks
Jeff
Thanks
Jeff
