My tj plans
cjshloman
Ok, cant afford a FT 6" kit sooooooooo, Id like to get some more clearance. I have a BDS 3" lift now, Id like to do a 1"BL, 1" MM lift, and keep the 33's I have. This is a quick economical thing, What do you guys do for the MM lift? Any good brand? I want a daystar BL cause its changing all my mounts. Any help, any suggestions? Id like to do spacers to, but again more money cause Id need a sye and shaft. Id like to save for a 5" or 6" kit in the future. My rig should do fine how it is now once I put my armor on that I have , and lengthen my brake lines. Any help appreciated, Bull.
this may avoid the need to do the MM lift.
sye $169 shipped. http://www.pirate4x4.com/forum/showthread.php?t=316786
and PORC is great to deal with, definately a good shop to spend money at. I called up and talked to em about buying lockers and they convinced me to wait and build up a set of Dana 44s, also told me it would be easier and cheaper for me to do it my slef local. but to come back when I wanted lockers for those.
Hey thanks for that site guys, I think Im gonna order that since its cheap, now Ill need the driveshaft. So with the sye and shaft, I can Ixnae the TC drop and MM lift right? Then Ill do a 1" body and coils maybe so Ill have a llittle more height. Bull.
