My 98 XJ was running fine all weekend during the Fall Crawl, but I had a problem on the way home. I stopped for gas and when I started it after filling, it revved up to 3000 rpm and wouldn't kick down. I was checking the throttle cable and other visual stuff, when Lou from Elias 4WD Center said hi to Laura and asked how it was going and she told him we were having a problem. He suspected either a vacuum leak or maybe the TPS. He tapped the TPS housing, but it wouldn't kick down. One of the vacuum line elbows was dry rotted but nothing to cause a massive vacuum leak. I was afraid to put it into drive at 3000 rpm, but Lou suggested that I shift it into drive right after I start it before the rpms get high. It worked and then seemed to run normally. So I pulled it away from the pump, stopped and restarted it, and it started fine. I just tried it again now and everything is working fine still.
Soooo... I don't think it's a vacuum problem. Should I just change the TPS? Any other ideas on what it could be?
BTW - I said it in another thread, but Lou from Elias is a class act. He and his wife/girlfriend? stopped to help us and then they even aired up my tires and offered to follow us home for a while to make sure we were OK.
