New Axles
pyagid
I picked up the new (to me) axles for my CJ today
Dana 44 Front dana 60 rear. Front a 1978 Jeep J20
A guy over near new paltz NY. He said he has every thing from 1946-1996 and then a Few TJ's. He said the only vehicle he does not have ALOT of are TJ's. If any one is looking for anything PM me for his number
they have about 70k miles on them. has 3.73 gears, but they have been sitting in a truck out in a farmers field for a long time, so they got a bit of rust. I will clean them up nicely though
I also just came across a J20 with the same axles, only front is Driver side drop, In west hartford for a descent price. Has 46k miles on it
-Paul
i just got the same set up for my grand :) i have some very different idies on how im going to do the suspension. my question to you is what are you going to do about a spare? the offset is going to be very diffrent between the front and back , beadlocks and just bring a tire . two spares or just use one that will stick out if its in the front?????????
you know if you keep it stock its allot less work. and it will make mine seem that much better \:D/
also what are your ideas on your suspension? leaf springs,coils ,controll arms ????????
Why do i need to run different offset wheels front and rear? I am not sure what i plan on running for offset yet, But i am going to use a uniform set.
As far as suspension I am going to run, front waggy springs at all four corners, SOA. And extend the wheel base 2" front and rear.
I am keeping the axles stock, width, I may convert the rears to disc brakes, and will eventually do a full locker front and rear
-Paul
sorry paul i just realized you got a better set then i. my 44 is shorter then my 60.
