redjeep
Moderator
A buddy of mine just stopped by and the lock for his wheel is stripped out. The new Cherokee's have full wheel bolts, not studs and nuts like normal. The guy at the tire shop just put the key on an impact and buzzed it right around. He has gotten 2 more new keys but can't get them to bight. I took a 2x4 and ratchet strapped it to the end of the breaker bar through the rim so it couldn't come out of the bolt but it still just spun. The end of the bolt is about 1/2 inch down into the aluminum rim so welding on a nut would be hard, never mind trashing the finish on the wheel.
He took it to Zellers Tire in Torrington and they couldn't get it off either.
Got any good tricks?
I'm wondering if I put the welding tip on my torch if I could heat up the bolt without trashing the rim too bad.
He said he saw on Youtube where they take a 12 point socket and smash it down over the bolt head. I was wondering if we could do that with a deep socket then use the stick welder through the 1/2 square hole to weld the socket to the bolthead. Hopefully welding inside the socket will, 1 heat up the whole bolt to loosen it, and 2 the socket would contain the spatter and heat so the rim doesn't get trashed.
What do you think?
I told him to give Toce's in Torrington a call and call the dealership to see if they have any advice.
What do you think?
