New style Cherokee Lug bolts
I was going to go with the beat a long 12 point socket over it, then stick weld through the 1/2 inch socket hole to help grab the bolt and put heat into it.  I figured that way there shouldn't be any weld spatter or too much heat getting to the rim.
Be slow, but why not use something like a Dremel cutting wheel or grinding stone on a drill to cut/grind away at it until enough was gone that you could remove the rest.  I’d probably try to cut a v out of it if it was me.  Prob slow as erosion but bet eventually it would be gone one way or another.
And worst case make a ritual sacrifice. Lol
