Rubi Rick
Just installed the Warn 9.5 ti in the Rubi. Install very easy. It worked fine for all of five minutes then nuttin'. I was respolling the line for the first time to stretch the line per instructions. I was in my flat driveway when the winch would no longer take in line. There was barely enough load to stretch the line properly. The overheat indicator light never came on. It will give line out fine but not in. No fuses blown, and the battery, although stock seems fine. Unhooked the positive and negatives checked to see if I somehow cut the wire insulation during the install but all was fine. Reconnected the wires to the battery and the same thing. What gives??? When I hit the toggle switch to respoll line all I hear is a click coming from the winch each time I hit the toggle switch.
I'm not too mechanically inclined but I really dont think I screwed this one up. I will be sure to let you know. Calling Warn in the morning.
