MasterDrazhar
I'm working on the brakes for my kid's car. The hardlines from front to back went, so I replaced them.
Now when bleeding the brakes I have No flow to the rear passenger side, and limited flow to the front drivers side. The front Pass and rear driver sides are locked up tight and won't release now.
This is on an '80 something Mercury Sable. The Master Cyl has 4 lines out, 2 each front and rear. The fronts are on the drivers side of the master and the rear lines are on the passenger side of the master. We did not touch the front, just the rear lines. The rear lines go back to some aluminum block which then has lines going to the left and right sides.
Any ideas what the hell could be going on???
