I've had oil seaping down the front of my oil pan for a while now and I'm having a hard time finding the source of the leak.
I've cleaned everything up that I could and at first I thought it might be the oil pan gasket.
I'm not sure now...I'm thinking now that the leak is comming from behind the vibration damper pulley. There is oil all over the timing case cover. Is it common for the crankshaft oil seal to go bad on the 4.OL?
Am I screwed?
Is it safe to still drive it?
Am I screwed?
