they make good springs and good shocks.
However the rest of the jazz in their kit is the same as everyone else. Simple bolts and brackets.
What size lift are you looking for? What are your main concerns? Longevity? Ride? Off Road ability? How much money... you throw enough money at anything and you will get everything..... :mrgreen:
OME make great springs, but only 2.5 is available in a kit. You can get great 4" coils but then you need to mix kits and brands.
My thoughts are, even though the OME is a good spring, only having a 2.5" lift is a bit of a high price at over $500. Being if you ever add a heavy bumper, winch, tire carrier, your expensive OME 2.5 coils can sag very quickly to a no lift.
There are many basic kits that will work, and then you can easy spend 2k without batting any eye.
So let start off with how much lift do you want? Ideally
Want it to still ride like a daily Driver?
How often will it see the non tar areas?
About how much would you like to spend?
Lastly, are you planning on adding to this lift later on to make it better, like add control arms, etc...
